Bob Morane
- Mar 27, 2021
- 7
Hello everyone.
As I am making the leap from week-end sailing to living aboard for the next 5-10 years, I'm contemplating a full refit of the solar and batteries on my Beneteau First 38.
It currently has 220w of solar panels and these are 18 years old and producing nowhere near as they should anymore.
In the same fashion, the house battery bank is composed of 2 × 100 AH 12v AGM batteries, both from 2016 and starting to get very tired.
Starter battery is the usual L-A starter.
The boat has a fridge, a small fan per cabin (x3), an autopilot and a VHF. Cooking is gas, no icemaker or freezer.
I have a small 300w inverter that I very rarely use for laptops, hair clippers and small power appliances.
Plotting and nav will be done on tablet and phone, no radar, very little integrated electronics overall apart from the depth sounder.
I plan to change most lights to LED and install a small watermaker which draws as little as 4-6A on 12v for 2gal/hour.
I will also have a 12v diving compressor that I will charge during the day occasionally drawing 4A@12v during 4hours for full charge.
I have roughly budgeted that I would need 130-180ah per 24h underway and ~80-120ah per 24h on anchor.
I want to be able to live on anchor for extended periods without starting the engine or using a generator.
I can start the engine for a few hours to run the alternator if necessary when underway but I'd like to avoid if possible.
With rough calculations, I came up with requirements of a 400w solar system and a ~300ah LFP battery bank.
I've been trying to fit the whole system within a 2000$ price tag which seems to fit with the solar system blueprints available on the site.
From the top-down :
1) 4 × 100w solar panel (400$)
Haven't decided yet which as I need to take a few measurements on the boat first and check the weight ratings of my arch.
2) 40A MPPT controller / 50A DC-DC charger (300$)
I'd appreciate any suggestions here as I am a bit confused as it is supposed to be 2 different components or there are controllers that do both solar and DC-DC charging and what makes the most sense here.
3) 4 × 310ah 3.2v Varicore LFP cells (550$)
This is the best I could find for simplicity of setup and cost effectiveness.
4) Daly 4s 150A BMS with BT. (120$)
Would appreciate any suggestions here as well. I am looking for something I can monitor from my phone and good enough for my use.Or maybe add a battery monitor I'm not sure.
I will be sailing tropical and temperate climate in summer so no need for a low temp cut-off.
5) Casing for the battery. (100-150$)
Very important as this will be on a sailboat going offshore, lots of movement and vibrations.
I have only started looking at what would work here.
6) wires, connectors, fuses, breakers, clamps etc (300$)
7) Tools (150-200$)
Which brings me to a price tag of 1800-1900$.
Is there anything shocking in that system ?
Does that seem to fit the usage ?
Are 280-310ah cells usable in a marine environment ? The battery will be inside and dry but moving a lot.
Any suggestions for BMS/Panels/Casing or general upgrades you think are necessary ?
Cheers and have a good day !
From the top-down :
7) Tools (150-200$)
