You want the UPS to shut down the stove?I am looking for a UPS that is also a small solar power station to safely shut down my pellet stove when the power goes out. Any suggestions?
I need something that when the power goes out, the pellet stove will switch over to a UPS to give it enough time to safely power down. I have tried UPS devices like the Tripplite that say it will work and they never work and I have to return them. So, I was thinking there has to be an affordable small solar generator that also has a UPS feature out there. My pellet stove has a peak wattage of 504 and contiual wattage of 200.You want the UPS to shut down the stove?
Or do you want the UPS to buy you some time so you can shut down the stove?
Come computer UPS systems have a signal able to tell the computer that grid power is off. So are you looking to use a signal to start an automated shutdown?
I just read what was printed. The Tripplite didn't work. And I tried another one that didn't work as well. I don't have a device that measure the wattage which I guess I should invest in and start learning more,.Why did the Tripplite UPS not work? The base APC 1000XL with internal batteries will run 200W for 80 minutes, and additional batteries will provide hours of stove operation.
One is cheap on eBay. Did you actually measure the wattage, or read what was printed in the specifications?
If you want to add solar then I would recommend an all-in-one unit. Watch the video:
Please describe how it did not work.Tripplite didn't work. And I tried another one that didn't work
And confirm the model number(s) of the UPS(s) that did not work. Some are garbage consumer duty, and some are hardcore industrial. the APC 1000XL is hardcore with an original list price approaching $1000.The Tripplite didn't work. And I tried another one that didn't work as well.
It was an overload because it would beep non stop and wouldn't power the pellet stove - it couldn't handle the pellet stove even though on paper it should have.Please describe how it did not work.
If it’s load, or switchover, or fault-out different approaches may be needed to solve the issue.
Not necessarilyIt was an overload because it would beep non stop and wouldn't power the pellet stove - it couldn't handle the pellet stove even though on paper it should have.
Are you expecting the UPS to command the pellet stove to do a "safe shutdown"?It was an overload because it would beep non stop and wouldn't power the pellet stove - it couldn't handle the pellet stove even though on paper it should have.
When the power goes out the pellet stove needs to shut down. I am always home when the pellet stove it on. I just wanted a UPS device hooked up to the pellet stove so when the power goes out it will not turn off and then I can just shut it down. Otherwise, the power goes off and then I have to turn it back on to turn it off so it can power down correctly which messes up the settings and is bad for the circuit board. When you turn off a pellet stove it still runs to cool down everything for another 10-15 minutes.Are you expecting the UPS to command the pellet stove to do a "safe shutdown"?
Please provide a product link to the pellet stove so we if/how it can be controlled.
See how much power the pellet mill draws with something like this https://www.amazon.ca/KINCREA-Electricity-Monitor-Voltage-Digital/dp/B07Q121ZQYWhen the power goes out the pellet stove needs to shut down. I am always home when the pellet stove it on. I just wanted a UPS device hooked up to the pellet stove so when the power goes out it will not turn off and then I can just shut it down. Otherwise, the power goes off and then I have to turn it back on to turn it off so it can power down correctly which messes up the settings and is bad for the circuit board. When you turn off a pellet stove it still runs to cool down everything for another 10-15 minutes.
