WorldwideDave
Residential structure in USA has grid service to a meter which connects to a 125A Cutler-Hammer load center.
Intention is to leave existing panel, and add an interlock device and a main breaker.
Currently have a single Quattro 48V 5000VA that was using for off-grid project.
Considering using this device to interconnect with the residence.
Thought about running critical loads panel, but instead will label breakers and turn off non-critical loads in emergency and will either connect cord (example: Generator connect at 30A or 50A - TBD) or hard wire inverter to the existing CH panel.
Early design phases here. Have enough panels, not enough battery yet, but racking mostly done.
Question: I really don't know the difference and/or advantages to adding a second 48V/5000VA Quattro to my existing one, OR just adding an autotransformer device.
I can get an auto-transformer (120V/240V/100A) for relatively cheap from a friend who is making changes on his yacht nearby, but a second Quattro costs a lot more.
Of course I know having bigger 48V Quattros or MultiPlus in the 15,000 range would probably be better. I'm sure it would be cheaper to keep the quattro I have for another project and just get an EG4 or something, but I can't just lump down 5,000 right now for batteries and inverter and labor to help with the interconnect on the panel, etc.
Really seeking a way to ease into this.
