I am trying to understand your mission on this forum.
To teach and to combat inaccuracies.
I am also translating my summary doc (to post or pdf ... donno yet) where I show (almost) all inverter usage possibilities like grid-tie (central inverter, microinverter, with and without limiter, Balkonkraftwerk), off-grid, off-grid with grid support (with inner limiter and with double conversion), hybrid systems like DC coupled, AC coupled (with auto transfer switch), single unit hybrid, grid-tie + UPS hybrid ... and all its benefits pros and cons with connection diagrams.
To have a common ground when someone writes grid-tie or hybrid.
To show users the possibilities to expand there system (even DIY in many scenario).
First I made this a hybrid study ... because every other day a different user came and asked that : "I have solar in my roof (GT) and still sitting in a dark in a blackout" (GT is used a lot here, OG is almost not known)
And what is your agenda?
a member asked what benefit or harm COULD happen without a holder… I gave a admittedly worst case scenario… one I have seen a great many times…
I am all about safety. But you misunderstanding the FUNCTION of the fuseholder.
Like you could say that Do not use extension cables ... because in a worst case they can go up in flames.
Yes, they can, seen it. And we still use them because 99.99999% of the time they don't.
you come on and claim the holder’s one and only purpose is to mount the fuse.
Seriously… why are you arguing about these points?
Because it is the fuseholder sole purpose. And to make easier to replace the fuse. There are cable fuses where you have to replace a piece of the cable with the fuse. It was a user made variant of that.
Most fuse holders are open. Do not have any plexy on the user side (sometimes the cabinet has that the fuseholder is placed but that is only for touch protection).
Really only 2 contactor. And, I showed you them, put in pics.
Have a backplate ... only to be a single unit. Like in first pic only a little backplate. And that is for a strong 160-400A NH1 fuse I think !
Sure, the fuse in the video didn’t fail or melt down or anything of the sort… it was an EXTREMELY brief short. It could have been far worse.
It was a brief short
BECAUSE the fuse blow.
See, here are some NH1 fuses I use too. This is a solar power plant. Also there is a dissection in the end.
