I'm investigating dc-dc charging options.
I have 12V 460AH Epoch essentials battery bank.
It would be nice to have shore power charging as well.
My first plan was to get some power converter like Powermax PM3-100LK Converter to charge from shore power (I need at least 75A to be able to run 12V Air Conditioner from it) and Victron Orion XS that can provide 50A for $320.
But with power converter I may have issues with Epoch battery as charging voltage must be no more than 14V, and it looks like most of power converter profiles use over 14V charging. I could set it to fixed 13.8V. Also Orion XS is limited to 50A.
I'm thinking might be car 12v->inverter 120v->12V Victron Multiplus inverter/charger be a good option instead?
I can use my current 1500W inverter to convert alternator 12V to 120V for Mutiplus shore power input.
Limit Multiplus shore power to 1000W and use it to charge battery while driving, and connect Mutiplus to shore power when needed.
I have Victron BM-712 battery monitor with relay I can configure to switch 1500W inverter off if engine is not running.
I assume there will be some additional power loss on double car 12v->inverter 120v->Victron Multiplus 12V conversion.
Have anybody tried that and how bad that idea is?
I'm on budget and Orion XS is pretty expensive for what it is, maybe a used Multiplus might be a better way to go?
