RandyP
- Sep 21, 2019
- 742
Dennis Wieske (Progressive Dynamics) discussed with Mike Sokol (RV Electric) use of Progressive Dynamics Converters to charge LiFePO4 batteries.
-This discussion reveals a change in the Progressive Dynamics PD91**ALV converter design currently in progress to change the converter from a one stage charger to a two stage charger (see youtube video starting at 37.3 minutes thru 39.2 minutes and on to 40.3 minutes for more info).
-Battle Born has stated that the PD converters made for use/charging with LiFePO4 batteries at 14.6 v (one stage) are acceptable for use with the B/B battery.
-I am glad to see the change to a two stage LiFePO4 PD**ALV converter. Apparently they will be available soon, if not already available. These 2-stage chargers will replace the one stage charger with no change in product part number. I never did like the single stage fixed 14.6 v converter for charging LFePO4 batteries because it holds the battery at 14.6 v as long as the converter is turned on (plugged in or 120v circuit breaker turned on).
