Frank in Thailand
making mistakes so you don't have to...
So much combined knowledge here I don't want to miss the chance on asking.
For LiFePO4 higher Amperage cells you connect the terminals with bus-bars.
Bus-bars that are bolted onto the terminal.
I personally use headless bolts as they place less stress at he weak shallow aluminium thread (only 6mm deep and max 8Nm torque!!!)
Anyway, to improve connection between bus-bar and terminal they obviously need to be cleaned and flat as possible.
I read that professional installers use silver electricity conductive paste. Expensive stuff!!
Many people use nothing in between.
Would something simple as solder paste improve the connections between the terminal and bus-bars??
Solder paste flux is non-corrosive
Solder paste have about 50% solder.
Naturally, a really thin layer, just to maximize conductivity.
It won't be as good as silver, but I think a lot better then nothing!
Positive is that it's easy to obtain, easy to use and not crazy expensive!
Both terminal and bus-bars (this is not yet bus-bar, now just copper bar) have minimal damages and the terminals have circles.
Flatening by filling the mini gaps should improve total contact surface, yes??
Or is it a dumb idea??
And if it is, why?
I already have 1.4ml silver conductive paste, and use this.
Probably won't be enough....
The order from 3 * 2.5ml turns out to be 3 * 0.2ml....
That will go back to the shop.
Price wasn't like 0.2ml
And if it is, why?
