As we used to say in the Navy : “ if it moves , salute it and if it does’nt , paint it “ .If it doesn't move, but should. Use WD-40. If it moves but should not. Use duck tape.
You must have been black shoe!As we used to say in the Navy : “ if it moves , salute it and if it does’nt , paint it “ .
Yea , black shoe.You must have been black shoe!
I was in the brown shoe Navy
Thanks for that link. I used a washer improperly and am now fixing it.Hedges. I am so respectful of your knowledge. But, what you picture is not what I addressed. You stated a "nut between the batter and bus bar". Never do that. If anyone wants to read more about stuff like washers on battery connections , with pictures, check here,; https://marinehowto.com/battery-melt-down-narrowly-averted/
Be sure to use a torque wrench.Thanks for that link. I used a washer improperly and am now fixing it.
You may have saved me a nasty fire or worse.
Everyone says that BUT.....Be sure to use a torque wrench.
Terminals in a battery are held by the strength of the plastic, which isn't much compared to metal. Too much torque and you break the seal, which could result in leakage or battery degradation. Possibly a greater issue for your lithium than my lead-acid.
Well if you had simply followed MY advice and used AGM, you could just RTFM!Everyone says that BUT.....
What poundage of torque?
And are ALL lifepo battery cell terminal the SAME torque?
That is why I go by feel.
Like the guy falling out of the building said. "So far so good.
Well being an old woman I think I can manage 35 in-lbs. Oh wait, I was a power lifter for 30 years and lifted the back end of small cars for funsies. hmmm. LOL"Terminal torque values: M6 use 35 in-lbs, M8 use 70 in-lbs"
Thank for the link but that is for lead acid batteries.
I have trouble with it because none of my torque wrenches go below 6 or 7 ft-lbs. Fortunately my batteries have 8mm bolts.Well being an old woman I think I can manage 35 in-lbs. Oh wait, I was a power lifter for 30 years and lifted the back end of small cars for funsies. hmmm. LOL
I will read those articles. Thank for the links.
The link was for galvanic problem, but I get the meaning.I have trouble with it because none of my torque wrenches go below 6 or 7 ft-lbs. Fortunately my batteries have 8mm bolts.
I have a similar problem above 75 ft-lbs because the Craftsman torque wrench my father gave me 40 years ago, which is still good, only goes that high. The other cheap ones I have kicking around that do go over 100 ft-lbs (for crankshaft pulley or harmonic balancer) are quite inaccurate. We played tug-of-war between the good and the ugly to get a calibration factor before using the cheap one.
"Thank for the link but that is for lead acid batteries."
That was just for reference, that name brands provide necessary specs.
For your lithium cells, be sure to read the diysolarform thread I linked (going back to update my posting) because it describes stripping out terminals. One guy managed to run a stud to the bottom after the fact and made it work without thread repair.
35 inch pounds would probably work but 8 nm = 70 inch poundsI think we stole this guys thread.
Ahem, um er. No, don't use solder paste . ??
No never..... LOLHere is that dreaded metric / imperial thing again. Metricate already ! ??
That is OK.I think we stole this guys thread.
Couldn't use nothing as it was loose and sparking and melting the plastic. Um er, or so I heard. ?That is OK.
Funny to see where the stories go..
From bacon to falling out of buildings
Washer between terminal and bus-bars/lugs for sure is not a good idea.
I'll be using silver "paint", the stuff you use to repair PCB lines.
Like any other paint job, clean aluminium surface.
It will seal the aluminium from oxigen / oxidation / galvanic corrosion.
(No oxigen = no galvanic corrosion)
I've tested the paint on aluminium heatsink that gets hot (+60 c) and cool (+25 c) a few times a day.
After a few weeks I can't see any problems with the paint, still looks as new.
Even added some salt water after a few days to extra abuse.
If that is not giving problems, I'm sure it won't give that problems at my terminals.
Oxi-guard probably is easier, this is better conductive.
Both have the same effect on galvanic corrosion prevention.
My Bus-bars are electroplated with Tin.
Stainless steel headless bolts / studs and nuts + washers.
Just to be sure, and low cost, I'll add magnesium wire touching aluminium, bus-bar and rod.
If there is galvanic corrosion problems, the magnesium will go first.
@BiduleOhm gave the tip to move the problem towards an area where it's more easy to control.
Next time I probably will use aluminium bus-bar and headless bolts for as long as I can to avoid the galvanic corrosion all together at the batteries.
This is as good as it gets
