apctjb
- Jun 16, 2020
- 458
Installing a 1000W inverter in my pickup truck (12V-100A max)) which will connect to my trucks starting battery. I was intending on using #4AWG cable for both positive and negative conductors (about 20' run from batter to inverter location) but ran across an article indicating it would be better to use the chassis of the vehicle as the negative conductor rather than running a separate negative conductor all the way back to the battery post. In other words the negative terminal of my inverter would connect to the chassis at the inverter, and the chassis to the battery terminal and the frame of the vehicle would be the conductor. I would use #4AWG to make the chassis connections
Good idea or bad?
Apologies if this topic has been covered previously, I am in a hurry to finish the install. Thanks
Good idea or bad?
