Newer (but still used) panels can be 20% and higher efficiency. That means 150% as much power in same area, on same mounting hardware.
$20/230W = $0.087/W, about half the lowest we've been seeing for new panels.
Some new panels cost more, and premium used panels do too.
I think Q-Cells, REC, SunPower are among the premium brands.
Some will fade more slowly. Polysilicon may fade faster.
Something important to consider is whether panels are "PID Free".
Some older panels degrade rapidly if biased to a voltage below ground. Some older SunPower panels degraded if biased above ground (e.g. negative grounded.)
Most inverters these days are transformerless, non-isolated. Half the PV string is biased above ground, half below ground. At least each is biased to only half the string voltage. But still, could degrade.
Cost of his system may be dominated by batteries, panel mounting hardware, and inverter.
He could start with these panels for $800, see how well things work out, plan to buy better ones if necessary some years down the road. But NOW is a great time to grab a good deal, due to disruption in the market. So consider new or premium (newer) used panels.
He should mount panels in a manner that easily allows replacement with different size. e.g. rails and top clamps if roof mount, NOT L-feet screwed to panel frame and roof.
