BarkingSpider
Carbon Lifeform
I have two 4kw battery banks, 1 AGM and 1 LifePo4 that need 2 different charging characteristics.
I currently have an existing 2kw solar array 4s4p at 80v to an Epever 40amp controller that is charging my AGM batteries no problem.
I want to try to connect my new LifePo4 bank to the same solar array and use the excess power I have to charge both battery banks.
I intend to connect a new charge controller to the same solar array in parallel to the existing Epever controller.
Has anyone done this before?
Will both MPPT controllers compete and cause problems
Should I use a PWM and a MPPT to avoid issues?
I want to avoid breaking up my existing solar array.
Any other suggestions?
