Not to be obnoxious... well, OK, just to be slightly obnoxious:You need a step down transformer.
With that being said, 12 Volts are for 12 volts only and 24 volts are for 24 volts only? No mix match, correct?An inverter is for plugging in AC devices. You would never plug a DC device into an inverter. You might have an inverter that is powered by a 24V battery but the inverter is outputting 110V AC (or maybe 230V AC depending on where you live). If you have a 12V device it is most likely DC.
If you do have a 24V electrical system and you need to use 12V items such as LED lights or fans, etc. then you need a 24V->12V DC-DC converter.
That is correct. But with proper components you can support different voltages as needed.With that being said, 12 Volts are for 12 volts only and 24 volts are for 24 volts only? No mix match, correct?
I don't believe that's how buck converters work; they utilize a PWM signal to control a switch, and they have much higher efficiencies than the linear type voltage regulator that I think you're thinking of. Buck converters are a switching power supply-- a lot of them have efficiency well over 90%. See the Victron Orion dc-dc converters for exampleNot to be obnoxious... well, OK, just to be slightly obnoxious:
That is not a transformer, it's a converter. A transformer works on AC.
Not only that, it's a buck converter. Which means it cuts the voltage to 12, and dissipates the rest.
Primitive, inefficient, and... hot ;·)
A PWM (pulse width modulation) converter (just as cheap nowadays) is a lot more efficient. It converts DC to AC, transforms that, and re-converts it. Sounds complicated and a waste - it isn't :·)
Wikipedia does ;·)I don't believe that's how buck converters work;
I wouldn't suggest that as a general approach. Many things will let out the magic smoke if you hook them up backwards.You just trial-and-error it.
Right from the wikipedia article:
If you need a more gentle power supply, track down a Doe converter.Not only that, it's a buck converter. Which means it cuts the voltage to 12, and dissipates the rest.
