using a hydraulic crimper for a 4AWG ferrule
rillweed
Massachusetts
On one of my connections, I have a 4AWG wire that needs a hex crimp to fit in a round terminal block. I have a temco hydraulic crimper. Would I be able to use this for the 4AWG ferrule instead of getting a normal ferrule crimper for this? I'm guessing normal ferrules don't cold weld the terminal like a hydraulic crimper typically does so i am not sure if this is acceptable
I have this crimper which is basically the same thing. I crimped 2awg copper ring onto 4awg wires and it crushed everything to a solid mass. I used the 35 die.
