I'm looking to use an AIO battery / PV inverter to power a subset of circuits in my home.
The "easy" way I can think of doing this is adding a breaker to the Main panel (Grid input to AIO), and then having the AIO output feed the sub panel.
This should work, but seems a bit inflexible; I want to replace the main panel anyway, and in the future if I want to move a circuit from the main to sub panel (or vice versa), it will be finicky.
I next thought was using a split-bus panel, but that seems to have gone out of fashion a long time ago.
My final thought was this:
What if I replace my split-phase panel with a 3-phase panel? Now, instead of two hots and a neutral, I'll have 3 hots + neutral. L1 / L2 will be wired to two of the bus bars as usual. The third bus bar will be the "backup" rail, and will be fed from the AIO.
EDIT: Arggg... lost the fancy image I made. Here's the low res cached one....
The benefit of doing this is that I can easily shift loads to the backup rail, simply by moving breaker position.
If I have a separate "critical loads" panel, it's a pain if I want to shift e.g, the garage fridge circuit, since I'd have to move the Romex physically between two panels. In this system, if I want to shift it to being backed up by the AIO, I just move the position so that it's on the "L3" busbar.
My AIO I've got is 5kW, so I'd still have to be careful about which loads I shift, but this makes it a lot more flexible and something you can do pretty easily.
How crazy is this, code-wise?
