using baseboard heater circuit/wiring for mini split?
afox
House was built in 1980 with 220v electric baseboard heat in every room. The baseboard heaters are on their own circuits (one circuit per room generally) and are controlled by a line voltage thermostat on the wall in each room. Id like to use one or more of these circuits/wiring for mini splits.
Could I simply reroute the wire going into the baseboard heaters to an outdoor disconnect leaving the wall thermostats in place and using them as a power disconnect?
Ive read that many mini splits use 15w when off/phantom draw so if they are not going to be used for days I could interrupt their power via the line voltage thermostats. If I rewire at the thermostat I would need a blank junction box at the thermostat location which would be unsightly IMO (these are typically adjacent to the light switch in a room). Not sure if keeping the wiring the same and using the line voltage thermostats as a power shutoff is harmful to the mini splits or to code. Alternatively, I could replace the thermostats with a 220v switch but seems like that would be more confusing to a user that doesn't understand the system than the thermostats.
I cant be the first one that has replaced baseboard heat with mini splits and used the baseboard heat wiring for their mini split!
Honestly I would think a thermostat that simply just cuts power to a mini split to be more confusing. "Why when I set it to 70 and it is 75 in the room the AC doesn't work?!"
Just put a blank cover. No, it isn't pretty, but it isn't confusing at least.
