My trailer sits for weeks or months at a time. I assume the SCC has a tiny bit of a current draw when connected during this off time ... to kill this draw, I thought about attaching the negative battery wire to the battery cutoff. Thus, when I disconnect, the battery from the trailer, I also kill the connection to the SCC. Is this OK? The negative is still potentially connected to a live negative from the converter in the trailer which may or may not be plugged in.... would a separate switch be a better choice?
the SCC says it uses a self consuming 10 miliamps. I assume that is .24 ah per day or 7.2ah a month? From my 96 AH of batteries, this would be on the order of ten percent per month. Is that right?
thoughts?
thoughts?
