I have a 23 foot travel trailer with 2 Zamp solar ports on the roof and a port on the driver's side wall. The existing SCC is the 10A PWM made by Zamp. The wire from the roof to the SCC is 10AWG (15 feet max) and the wire from the SCC to the 2 220Ah 6V GC batteries is 8AWG (20 feet max). There is a 20w Zamp panel mounted on the A/C unit which serves as a trickle charger for the battery.
I would like to NOT have to pull new wire. We have modest power needs. We occasionally use a 500w PSW inverter, which plugs into a 12v socket in the camper, to recharge our GMRS radios, an 18v battery for a Bosch vacuum and drill, and of course the water pump, refrigerator, LED lights, and 2 Maxxair fans. If we are out camping, we are outside doing something except to sleep and occasionally eat. This past weekend, after 2 full days of boondocking, our battery monitor showed that we had used 36% of the battery capacity. This would be the norm.
I am looking at a 3 panel, 600w kit, which will just about max out the open space on the roof. The kit comes with a 40A MPPT controller. We live in New Mexico and typically shading isn't much of an issue. Will I be able to use the existing solar ports on the roof to safely and efficiently recharge my batteries? Thank you.
