gcp
Going nomadic.
- Sep 1, 2021
- 49
Hi there. I've just about completed my first ever solar/power system build out (diagram below) after much studying and learning from folks here. I have a question about using my inverter charger with shore power while disconnected from my battery bank.
Today I had the following conditions:
Camper was connected to shore power (30a), which goes directly into my Renogy 2000W Inverter Charger.
I disconnected the battery using the battery cutoff switch.
Inverter Charger immediately starts beeping, but shows no warning/error code. Just the "Fault" light was lit up. Will not stop beeping.
120AC systems continued to function just fine.
This made me wonder: is it not appropriate to use my inverter charger to power my 120v AC systems when connected to shore power but not connected to my battery bank? Should I have shore power routed to both the inverter charger as well as my AC breaker box?
I didn't see anything in the Renogy Manual about this, or in the Renogy support site. I haven't contacted them about it yet because my experience with them is like everyone else's: not helpful. Don't get me started on Renogy - if I could do it over again, I would not buy anything from them.
I appreciate any advice you can offer. Thank you!
