Hi All
I plan to use some spring washers on the M6 terminals for my Lishen cells with threaded holes (using grub screws and nuts, not bolts).
I'm very concerned about how easy these terminals are to strip and figure the spring washers will give me a good indication of the when the nuts are tightened sufficiently and also provide some protection against them working their way loose in the RV/Caravan (lots of movement) they will be used in.
Do I need to be extra cautious with these spring washers as I don't see them being used in any of the videos on these types of cells, I have no first hand experience with these cells and am quite alarmed at how little force the recommended 4nm actually looks on video. Could these spring washers require additional force which could be too much?
Thanks
Thanks
