hi all, newbe with a question on using a victron IP22 110v smart charger as or inplace of my RV converter in newer RV ?
first we have 400 watts of roof solar, 100/30 victron MPPT charger , victron battery minder for low temp shut down and a 200AMP chin lithium with a 2200 watt inverter.
the victron IP22 110v charger can charge lithium @ 30 amp or 15 amp selectable and also has a setting for converter or charger mode, right now I use as 110 ac charging lith.ion battery when on shore/generator when we need to boost the battery due to insufficient solar to use ratio. say once a week. WE HAVE the RV converter off so 12 v runs on battery only even when on shore/generator where the IP22 charger is used and set to 30 amp charge .
This set up seems to work great so thinking of removing the existing rv charger/converter and installing the IP22 in old converter hole in electrical/power panel spot.
I should probably consult victron too, as the IP22 does put out some heat when set on 30 amp charge , Any thoughts on this or cautions ?? ???
thanks Jerr
thanks Jerr
