I have an EPEVER UP5000-HM8042 inverter. (220V) The inverter comes with Line and Neutral input terminals (from utility power) and separate Line and Neutral output connections for the solar system driven loads. (also a separate common Earth Connection). All my loads (inverter driven and normal utility driven) have individual neutral returns all connected together to a common Neutral Bus at the main breaker box. At this main breaker box, the neutral bus bars are connected to the Earth Bus Bar. Question: Do I need to separate out my inverter load neutral returns and connect them to a new neutral bus which in turn is connected to the inverter neutral terminal, or can I tie the input and output neutrals together to the existing common neutral bus.
Many thanks,
Dan
Many thanks,
Dan
