I am still trying to understand these terms and their meaning in real-world applications.
1. Utility priority output - Saw this in an ad for a SunGoldPower SPH6548P ("6.5KW 48V Split phase solar inverter). The description says: " Utility at first priority, utility and solar provide power to load at the same time when solar is available, battery will provide power to load only when utility power is not available. (Priority: Utility>Solar>Battery)"
- This sort of setup seems ideal for what I would like to do, and at around $1200, it is budget-friendly. However, the reviews for this unit and Sun Gold Power in general are not very good. Are there similar units from other companies that are more reliable? (Yes, I'm sure the EG4 18K fits the bill but at $5k it is not a viable option)
2. SUB - It seems like this setting stands for Solar-Utility-Battery and, in theory, would blend power from sources in that order to meet the load demand? I've seen this on some lesser known units in the Sub $1200 range, but most units instead seem to only offer SBU priority
3. Grid Shaving - Sounds like this operates similarly to an SUB scenario except that maybe you can limit the total draw from the grid?
4. Blending - Trying to determine if this term is an appropriate search term to help identify units that will power a load with some mix of PV/Grid as opposed to all PV or all grid.
5. AC coupling - Seems like this term may be analogous to blending?
Thanks!
Thanks!
