albrittbrat
I am in the process of commissioning my solar system. I have 40x talesun 395W panels on my roof, an EG4 18KPV hybrid inverter, and an EG4 280Ah indoor wall mount battery. The solar is already wired to the inverter and the inverter to the battery, all good there.
So after waiting a full month for my power company (Ameren IL) to get back to me on my solar/net metering application, they are saying I have to have a red lever disconnect between the meter base and the inverter - no problem there, can do that easily.
The problem is they are saying I have to have a separate red lever disconnect for my battery. The meter base is on one side of my house and the solar equipment is in the owners closet next to the main house panel, clear on the other side of the house. Over 100' away if you factor in up and down. You arent supposed to extend battery cables at all, much less hundreds of feet.
So my question is, does anyone know of any kind of remote control disconnect? Or a massive 48,000 Watt relay that doesn't humm horribly? The battery uses four 2/0 aluminum cables, two red and two black to connect to the inverter.
Thanks!
Thanks!
