svetz
Works in theory! Practice? That's something else
No, not a free energy device. Also, not very practical.... so don't bother reading further unless you just like weird stuff or happen to live underwater.
This is the reverse of compressed air energy storage. I was curious how the math would work out after researching an earlier post. Compressed Air technology has a few things working against it. First is that while compressing the air the work put into it also has to pay for the heat being squished into a smaller volume. Second is that increasing pressure isn’t proportional to the energy gain, it’s limited by
With all those things working against it, I wondered would they work for you if you created a vacuum rather than compressed the gas? From these rough calculations, it looks like there are some things that work for you and some things to be careful about; but not really practical overall.
The pressure gradient between the two is ~14.6 psi. Since it’s a near vacuum on the other side there isn’t much heat so with a near-isothermal process we could expect an efficiency of 92% and a pump efficiency of 80%, for a combined efficiency of 73%. That's a lot better than CAES too.
From Wikipedia for CAES,
So, how many kWh per cubic meter?
0.1013529 x 1 x ln (14.7/.1) + (0.1013529 - 0.000689476) x 1 = 0.5057948149 + 0.100663424 = .6 MJ = .16 kWh/cubic meter = 4W/cuft
But, that's not what's happening here as the pressure is always atmospheric on one side and .1 on the other. In CAES as the fluid moves the pressure changes.
The vacuum system has constant head as long as you're under the systems C-Rate (in this case that would be the rate of the vapor on the vacuum side returning to a liquid form, e.g., condensation). So, the equation would be:
Ph(kW) = q ρ g h / (3,600,000); or with pressure = q p / (3.6 106)
where:
Solving for q for 1 kW, q = 3,600,000 / 100,000 = 3.6 m3/kW
The average U.S. home is 2687 sqft and consumes 30kWh/day. So, how many m3 would you need for 60 kWh?
60x3.6=216 cubic meters, 57,000 gallons, or about 3' deep for each vacuum tank excavated under your 2687 sqft home.
If you assume 70% efficiency, it would be more like 4' deep per tank. That's a lot better than low-pressure CAES if the math/assumptions are correct.
The cost of getting a vacuum tank that size that could withstand the pressure would probably be prohibitive, I'm not sure that burying it confers any significant advantage.
So all in all it doesn't look all that practical considering the size/cost of the tank needed. Even though increasing the pressure on CAES is a losing proposition, it does allow you to get a higher energy density.
What? You made it this far and wondering what the "you live underwater" had to do with it? Simple... If you lived just 33' under water than "atmospheric" pressure is two bar, that halves the volume requirement. The deeper you go the less volume you need.
First, let’s propose how it might work. Imagine a tank filled with water, that’s the battery discharged. Pump all the water out leaving a vacuum behind, that the battery fully charged. We’ll add some ethylene glycol to the water to reduce it’s vapor pressure to say .1 psi (that is it’s not really a vacuum, just as well as the tank would collapse). The atmospheric tank is nothing special, but the vacuum tank needs to be strong to keep from getting crushed. |
where:
Ph(kW) = hydraulic power (kW)
q = flow (m3/h)
ρ = density of fluid (kg/m3) = 1000 kg/m3 for water
p = differential pressure (N/m2, Pa)
