Ryantech
- Feb 1, 2021
- 16
I have shielded solid strand wire I'm having an issue with as I did with cat 6 wire. Data and voltage lines are all physically separated and all shielded. The yellow heat shrink run is my data line. Mod A is red; Mod B is black. Mod A is hooked up to the 3rd pin on the connector; Mod B is pin 4 on the connector. Valance software was able to verify I still have coms to the batteries. Data and voltage lines are about 10'-15' in length. Bms is located in a weatherproof area but batteries are in a water splash area being that they're underneath the trailer. What in the world am I doing wrong if at all!?..
