Combiner boxes typically have a DIN rail for breakers or fuses, so that would be inside the box.
Sometimes pre-assembled, often sold empty to be configured as needed.
MidNite Solar Product Page.
www.midnitesolar.com
MC4 is typically rated 30A, and some "Y" cables are made with 8 awg. Unless it had a special MC4 connector rated 55A, and you were sure the mating cable also had a compatible MC4 connector of same rating, couldn't rely on MC4 to carry the combined current.
I think if you got a 4-Y cable, or three 2-Y cables, you could just cut off the MC-4 connector which would have had to carry the combined current and splice it to the home-run wire. Put four MC-4 fuse holders on the Y cable and connect to PV panels.
MC4 fuse holders aren't touch-safe but the MC4 connectors are, so disconnect both MC4 cables before opening. Interrupt current flow before disconnecting, so not under load.
I think I've heard that new/future requirements are that PV breakers be non-polar? If so, that solves my concern that the polarized ones can't actually provide the protection they were supposed to. A 4-pole breaker (all poles ganged) would work fine even if polarized. Fuses are good, but don't serve as a disconnect under load. Four touch-safe fuse holders and a breaker as disconnect would work, or shut off charge controller by opening breaker on battery side before opening fuse holders.
This is the one I wouldn't trust unless the breakers were non-polarized, or had a wire slipped through the handles to gang them. I haven't heard of any faults that they should have interrupted and didn't, just expressing my opinion/analysis of the breaker ratings and required performance.
Prices on those all seem high, but vary from difference sources. It is the breakers and fuses themselves which particularly need to have the right voltage/current/polarization specs.
