CaySol
Solar apprentice
Apples to oranges then. Hard to suggest 60v arrays for the rest of us.I couldn't burn through that much power even if I wanted to. Yikes.
They say it can happen pretty quickly, not years. Up to 70% loss. Also, the bifacials may be more susceptible.I read the paper you attached about PID damage - seems like by the time there is enough damage to cause a problem cheaper, more efficient panels will be available to replace them. And that assumes you have a good way without panel level electronic to detect the reduced output from PID damage.
The only way PID damage affects us with reduced production is by a short to the panel frames...
very true, multiple small arrays wont' work for everyone.Apples to oranges then. Hard to suggest 60v arrays for the rest of us.
Gotta dig into what caused the fires. Modules for sure are more likely to catch fire at higher voltages due to insulation failures, for obvious reasons. Ive seen that many times.Thats what they tell us yet, panels catch on fire and higher potential is exactly how it sounds.
I have been researching it allot recently and unfortunately, no one really knows 100% what is going on with it. There was a thread a while back by a gent from Italy that thought he had it but I don't know if he ever tested. Panels have to be marked in order and tested separately.So far in reading on this forum I have only ever seen you talk about PID damage, unless it is a response to you.
I deep dived on it a long while back and its a fascinating subject. Here is a brand new panel (mine) that is already eager to die an early death. Check out that bad boy cell. Don't worry, I'm not pushing much power through that cell, its a small array.Gotta dig into what caused the fires. Modules for sure are more likely to catch fire at higher voltages due to insulation failures, for obvious reasons. Ive seen that many times.
If you ref the blue in the target box @28c then your looking at about 37c Delta. It was a cool day. It felt noticeably warmer. Its brand new and with low power passing through it will be fine. I would not put it in a high power array.what's the Delta t between that cell and the surrounding ones? is that the 7-8 deg c?
10 AWG solar wire would handle it but to be on the conservative side, I would go with #8 AWG. I am assuming you are also using Victron Inverters.Hi everyone,
I am considering purchasing a property that I would have a very long distance between the solar panels and the mppt.
I don’t know exactly details yet… here is my best guess… of what I would have - I am not sure how to figure voltage/amp drops over these distances. I have just picked items to get close enough to ask questions with real numbers.
Distance - 1700 feet
Mppt - Victron 450/100
Array 1. Eight 405-ish panels in series (Voc 45.6 Vmp 37.9v Isc 10.69a -
So Voc 369v Vmp 303v Isc 10.69 - Total watts 3240w
Array2 - exactly the same.
Cable - Aluminum Direct bury 4-4-4-4 - yes way overkill for 10.69 amps, but at $1.55 ft it’s either the cheapest or same price for much larger thicker wire.
It can get to -20 degrees C in the area.
What are the voltage and amperage losses going to look like? And how to I figure them out for a run like this?
Thanks
I've averaged 163 kwh/d so far in Jan with 3 days over 200. My peak was 244. The two EVs is what makes it jump up. It's a 60 mile round trip to anywhere.Sure, but to move any meaningful power at 65V, it’s a shit ton of amps. Not all of us have power demands that are low. The last 3 days, I’ve used 130+ kWh a day in my 2100 sq ft house.
Everything is a trade off, of course. I could never justify the system I’ve got at 65V from the array to the house, the cost of copper would kill me
The forward bias on the diode likely not there yet. Thats the problem with bypass diodes, its only a partial fix.Ok sorry I misread the scale. Yeah at 38 Delta T that bypass diode should probably be on and the module power down by a third if there are 3 diodes. You can tell because the diode will be hot too. Not gonna catch fire though.
depending on what state you reside code varies enormously on earthing, regardless imho, a local earth rod to the pv array frame is essential and it should also have a surge diversion earth point, that is bonded back to another earth rod at the mppt controller. bonding is massively important to reduce differential voltages induced from lightning during a storm. Do not have separate eath rods that are not tied together. Voltage differentials can and will kill lots of electronics.Ok this is where my knowledge (RV stuff) ends.
Ok I knew that I needed to tie all the ground mount panels together- but I was under the impression that the ground would go to a ground rod driven next to the array, not all the way back to the mppt. Sounds like my impression is incorrect…
Why does the ground go all the way back to the mppt (and then to the earth) and not just to the earth? If it makes any difference- this is completely off-grid.
an earth “circuit” is not for fault current ( that is what a earth neutral bond is for) it is to provide protection to people and hopefully from stray voltages aka storms and so on. regardless an array should have its own earth rod that is bonded back to another at the mppt or pv controller. there are no guarantees a local strike can generate enormous (stupid!) voltages across even bonded earth points…So running a ground wire from my array back the the same rod that my house is grounded on, not ok?
This is what I do but IIRC, it is no longer recommended to retorque the connections.I'm with you on using direct bury Al over that distance. Put some antioxidant paste on the terminations and retorque them a couple times.
If you go with 6/2 Al you might be able to use a couple IMO isolators at your array and make the transition from your module interconnects to your Al conductors in those. You should have disconnects at the array anyway. Pretty sure the IMOs can take 6 awg, not certain the terminals are spec'd for Al though.
Yeah there is a debate about that. The argument is that you get cold flow in the conductor so when you retorque it, it will be compressed further, then cold flow some more, etc. But OTOH if it's actually gotten loose you have to retorque it or it will overheat. Probably the best thing would be to do an IR scan under load and if it's abnormally hot retorque it, if not leave it alone.This is what I do but IIRC, it is no longer recommended to retorque the connections.
It sure is. Also the harder the pull the easier it is to cause insulation damage. It's standard practice to megger all buried conductors on commercial and utility scale PV installs and insulation failures on pulled conductors are quite common. Another reason I favor direct burial over conduit, as long as you don't have a colony of those subterranean murder squirrels....FYI, it is a pita pulling that stuff through conduit.
