I'm finding lots of those adds having it way overrated when I bought my 2/0 it was also overrated but not near as much.My preferred wire gauge calculator agrees with your assessment that the wire is overrated. I wonder how they came up with that.
I have the drill press covered I have one the heaviest self-tightening vises and multiple self-tightening clamps. I hurt myself years ago playing in my grandfather’s garage drilling and rc chassis when I was very young. I'm just shocked how much more force it takes to do the tapping vs steel. I did make the mistake on the first few busbars not having that secure enough for the saw. So, I took the time to make it much safer with no clearance and flush with the saw to help. I wanted to show the idea incase anyone else uses a bevel saw to cut copper to beware of the issue.Make sure you're safe from injury if a work piece is grabbed and spun. Ideally a vice or something.
Have a dado blade? could make a notch to fit the busbar.
Could be a different bit, different grinding angle would perform better. Or a punch.
I had a piece get away from me on the drill press. I finally saw the light and bought a good quality drill press vise. No more accidents.
I learned quickly how dangerous a drill press can be very early, and cutting copper which I will stick with the term grabby. Here's my setup vise is 32lbs you can get bigger but not in quick adjust with self tightening.I've also had a table saw chuck a board into my gut. Later, into a patio window (it is single-pane now).
I got a push stick for splitting lumber (like 2x4 --> 2x2), but don't like that it requires pushing down toward the blade.
I've finally realized I should make a pusher that rolls on opposite side of rip fence, with a piece that reaches over the fence and passes near blade.
Drill press is still a problem for some work pieces. I've had close calls.
