Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,060
Not sure exactly what isn't fitting for you, but I'd think you could use u-bolts to attach some kind of rails (u-channel perhaps; mine are unirac solarmount rails with angle aluminum) and make it work.
So long as you've got two horizontal runs of pipe that are anywhere near parallel, should be good enough for the panels.
Many of my uprights were floppy, so I adjusted where on the rails they were bolted to get an approximately planar surface.
I was bolting most of them to existing anchor bolts in an old foundation, so they're at crazy angles. Others I pounded into the earth.
