Currently 80 500w panels, 4th charge controller is mounted but need to figure out where else I can add 20 panels. Today was really nice for production with total 124 amps being supplied between the battery banks.
Can you provide more info on the question, some of the data in solar assist like load apparent, which I really could not find anything on.40 kW?
167A at 240Vrms?
It was on the 48 volt side going into the battery banks.124 Amps at what voltage? 48 volts or 240 volts?
Thanks for the clarification, I was not sure about the numbers since I was thinking of the max amps I had achieved and was unsure of the 40kwh number. I would like to add 22 more just for the safety margin. Since cloudy days have cut production by 70% or more.Did you say you have eighty, 500W PV panels?
That would be 40 kW (STC)! That's a lot - if grid-tie, would approach 167A backfeed at 240V.
But the charts and numbers show things like 210 kWh PV for a month (for one inverter?) That would be more like 1.5kW
Solar assist reports 45w, the batrium showed even less on the battery side.@kromc5 Are you running the Growatt 12kw inverter? What is the idle power draw for this inverter? (finding it hard to get any info like that about it)
I'm not sure on that one but I can check them later today an report back.@kromc5 Thanks again for your help. What is the stud size of the batter cable connection on the inverter? M8 or M10?
I grabbed the smallest lug I had which is slightly over 5/16, so I would say its m8 since it was slightly looose.Thanks.
M8 = 5/16"
M10 = 3/8"
Looking to start buying lugs and cables before the inverter gets here
