It's inverter 1 I have not removed the cover on it yet going as I will wait for signature to call. The smell was completely overwhelming from the fans.Search with your nose. Cooked electronics maintains its odor long after flames are no longer visible.
Could be your system (most likely), might be something else.
I did go on and install the new board, waiting on one from signature but wanted to get back up and testing quickly.Did you get the new boards installed? Do you think they will be more robust?
So you had to break up the arrays? It would be interesting to see see a comparison between your old arrays designs (series / parallel / number of PV inputs / number of SCCs) to your current or planned new set up.
- what are the differences in VOC per pv input
- differences in array watts per pv input
Had to get more 3 inch pipe to tie in to the house and run another 75 ft of 6awg. I have split all the connections on the larger row of the panels. The interesting question is will this produce more power? One inverter, one charge controller now have 9 panels on each pv input. Inverter 2 has 9 on one pv and 6 on the second. Also interesting the replacement board for my 150v inverter has 6 250v caps instead of 4 160v caps, I doubled check via two sources before installing to be safe.
The small wire is for the midnite surge suppressors.Your pictures have a couple skinny wires going to same lug as fat wire, fed by 3x 20A circuits.
What is that for? It isn't protected for the current it would carry if shorted. You have spare tabs on the combiner bar, so could install a breaker for it.
I was specifically told I was over-paneled, I was told by one tech to keep it under 6 panels another 12. I have broken themIn the big picture looking back, do you think your SCC got smoked from being over paneled? Or some other reason?
Thank you for the information I will look addressing the wires. Sadly having to pull all the wires once and then move everything around has left the wiring not very clean from the panels/combiners. I have alot of wiring cleanup that needs to be done.Slow-blow fuse or time-delay breaker would be appropriate.
The wires appear to route near opposite polarity busbars, and probably can't carry short-circuit current from array.
Or at least an extra protective sleeve. For routing of twisted pair cable inside my inverters, the accessory kits came with a silicone tube intended to contain splatter if wire blew (like fusible link in car.)
I think the Midnight suppressors have MOVs with thermistor or similar device to open the circuit if MOV fails shorted. Some status lights, would show protected/blown in an AC application but I think their instructions said some of that doesn't light up for DC.
e.g. using parts like these:
TMOV20RP460M Littelfuse Inc. | Circuit Protection | DigiKey
Order today, ships today. TMOV20RP460M – 750 V 10 kA Varistor 1 Circuit Through Hole Disc 20mm 3-Lead from Littelfuse Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
If you take the lowest watt number the panels can produce its 3330. Its fustrating to see both inveters with large deltas in pv current since they both have identical panels/numbers on each pv input.So you got right about 3000 watts coming in to each PV input so far this morning from each array?
