I had read somewhere that you should set your float voltage around the batteries "resting" voltage. My batteries seem to settle at 13.3V or 26.6V in series. That is why I had my settings at 26.40V, Absorb = 27.80. Would you suggest something different?
There's a lot of misinformation with LFP and float.
If you're going to charge one up and store it, correct. You don't need float.
If you're going to put it into a solar power system, then you need a float that will 1) not overcharge the battery and 2) establish a "floor" of operation for the MPPT.
3.45V/cell will get to 98% SoC, but it may require a longer absorption time (1-2 hours)
3.55V/cell will get fully charged with a short absorption period (15-30 minutes)
If you aren't in a hurry (solar or shore power), 3.45V is good.
If you're charging by generator, 3.55V is the way to go.
3.375V is a good float voltage.
Make sure that your two 12V are reading nearly identical voltages when the system is in absorption.
Hopefully, you did it, but it's important to charge both 12V to full individually and preferably give them an hour at 14.2-14.4V prior to wiring them in series.
