The best I understand an MPPT charge contoller, the input voltage/amps from the PV is efficiently reproportiined to the lower voltage of the battery system. The max current the 100/50 is 50 amps.
I checked each of my six array panels on a cold day a couple of weeks back. Voltage check was open circuit and the voltmeter read 45-46vdc. This was higher than the panels listed "max power voltage" (41.1v) and lower than "open circuit voltage" (49.1v)
"max power current" is 9.86a. "Short circuit current" is 10.37a. The wattage listed is 405.
I assume if these will make a loaded current of say an even 10amps-ish, two panels in series 45+45=90v will be OK for the 100v max, but proportioning that 90 volts to 13 volts at the battery gives a ratio (90 panel volts ÷13 battery volts =) a 6.92 multiplier for amps. 6.92 × 10= 69.2 amps. That will smoke that new Victron 100/50, correct?
Is my math right?
Is my math right?
