RoboWarrior314
- Jun 27, 2022
- 1
Selling my 1kw (exactly 990 watts) solar system. We purchased a solar kit from Arizona Wind amp; Sun and wired/mounted on an RV. We used it for 9 months while living in the RV. But decided to get a home base and got rid of the RV so we no longer need this system. It's all wired an ready to go. Just need to mount the board, panels, and wire the panels to the system. Extremely easy to setup. We installed the whole system in the front pass through storage of our RV, still had ample space for storage.
Northern Arizona Wind & Sun have been excellent with their customer support!
All high quality Victron components top of the line system! The batteries are 200 amp-hr each and are from Dakota Lithium.
Again, we've had no issues with this system. I would be willing to separate out the batteries from the rest of the system. With batteries I'm asking $10,500 since it's wired, laid out, mounted, and tested extensively. Without the batteries I'm asking $6,000 for everything else.
I have the original bill of materials, manuals, and other documents to support the system. Here's a list of the primary components:
REC N PEAK Series 330 Watt. 120 half cut cells, monocrystalline module with MC4 connectors. Vmp: 34.6, Imp: 9.55, Voc: 41.0, Isc: 10.33, 65.9" x 39.25" x 1.1" 30mm , 39.7 lbs.
Victron smart battery monitor. 500A/50mV shunt is included. No display
Victron MultiPlus inverter amp; charger. 3000 Watts, 12 Volts DC, 120 Volts AC, 120 Amp charger.
Interface MK3 USB VE.Bus to USB .The Cerbo GX provides monitoring, and operates as the communication centre of your installation.
The GX Touch 50 is the display accessory for our Cerbo GX. The five inch touch screen display gives an instant overview of your system.
Smart BatteryProtect 12/24 100A.
Victron SmartSolar MPPT 150/85 Tr VE.Can solar charge controller. 12, 24, 48 Volts DC.
Shipping would be difficult and the panels are rather large but I'm sure we can figure something out to safely transport everything. Only inserted 1 picture, other pictures are attached.
