peterjk
- Jan 10, 2021
- 81
Hi everyone,
I am building a small portable solar box, with 8 200ah lithium batteries in series = 24v. I want to convert that to 12 volt for a small 12v dc fridge and a couple diesel Chinese heaters, also 12v. They don't pull much, around 8w when running. anyway, I purchased a victron 24/12 40A converter, but I cannot locate a wiring diagram for it anywhere. The MFG directions are absolutely silly, and not descriptive at all on how to wire it up. Looks like on the left side is says Input 18-24, I'm assuming that is where the 24v pos and neg will connect, but I don understand that layout, there are two connectors on the top and one on the bottom in a V shape, so not sure at all which wire goes where. If anyone, if anyone has wired up one of these, can you please share. Maybe I should return this one and go with the 70A, seems more folks are using that one. Looks like #2 is a Ground, so either one can be used? That leaves the two terminal on top left, are they both POS 24v ? and the two top right would both be POS 12 ?
