adrasto2006
I just purchased and installed a victron 150/100. All of my previous controllers have had flooded battery profile. Not so with the V 150/100. You can define a custom profile, but before I create one, I thought i would ask the group for their recommended settings.
My battery bank is 6 6 volt Duracell 230 amp (690 ah total) flooded acid batteries in series/parallel. Each pair connecting to busbar Using equal distance cabling. I also have a victron 500 amp shunt and a battery temp sensor.
My panels are two 430 watt panels in parallel. WEUP WP430PM5-60SB solar panel:
Maximum Power (Pm): 430W
Voltage at Maximum Power (Vm): 35.63V
Current at Maximum Power (Im): 12.07A
Open Circuit Voltage (Voc): 43.28V
Short Circuit Current (Isc): 12.67A
Maximum System Voltage: 1500V (IEC)
Maximum Series Fuse Rating: 20A
Dimensions: 1723 × 1134 × 35 mm
Weight: 21 kg
Output Tolerance: 0 ~ +5W
Standard Test Condition (STC): 1000W/m², AM 1.5, 25°C
Operating Temperature: -40°C to +85°C
Weight: 21 kg
