John Frum
Tell me your problems
- Nov 30, 2019
- 15,234
Victron bp-65
to reproduce:
make this setup:
battery.pos->fuse->bp_in->bp_out->fuse->inverter_ext_switch_terminal
battery.neg<-bp_pin_1.2_ground
Set the power switch on the inverter to external switching mode
baseline: Open the fuse between bp_out and inverter_ext_switch_terminal
notice the inverter turns off
reset for test
test: remove the short between remote 2.1 and remote 2.2
Expected results: the inverter should shut off
Observed results: the inverter does not shut off
Is my test valid?
How can I make the battery protect shut down my inverter?
to reproduce:
make this setup:
reset for test
Is my test valid?
