OK, investigation complete ... don't use the 'Remote' connections. These are solely for turning the BatteryProtect on or off i.e. just a master of/off switch. You need to use the Alarm terminal.
The Alarm terminal basically provides a ground return when it activates i.e. depending on voltage IN and whatever programme is selected:
And your inverter's (
when switch to EXT) Terminal Block 4a has an opto-coupler that is seeking a power supply referenced to an independent ground in order to activate:
So you should be able to mary-up the ground-seeking circuit to the ground-providing circuit to control the inverter either by:
- Providing a ground for the in-built supply that I assume is offered on terminal 'S' (Option 1) OR
- Provide both supply and ground to terminals '+' and '-' (Option 2)
Now unfortunately, this will turn the inverter on when the BatteryProtect tells it to turn off!! I'm working on that, but for now, my brain is mush - I need some sleep!!
