I am converting to Lifepo4 280ah diy battery from LA. I have determined my PD9245C does not have the correct charge profile to charge this battery.
I plan to leave my converter in place to power my 12v. system when on shore power. Can I do this and not have it charge my Lifepo4 battery? Is this possible?
I am considering adding a Victron BlueSmart IP67 Charger - 12 VDC - 25AMP BPC122547106 to charge my battery instead. I believe it has a good charge profile for LI. I'm not certain I can use this to replace my PD unit altogether? Any thoughts?
I plan to boondock mostly and will have 645w. of PV wired in parallel using a Victron MPPT 100/50 with blue tooth. I also plan to have the alternator charge my battery when running the class c rv. I want to add the charger in case I may need it when the solar and alternator may not be enough.
Open to any and all comments and am aware I may have to add a DC-DC charger to protect my alternator.
Thank you.....Steve
Thank you.....Steve
