YES, it has plenty of space and is mounted vertical.
Volts/amps are within operating range. I should not need to build a cooling system for this $950 controller.
I don't disagree. Again, I've never had mine that high. As
@MisterSandals indicated, the entire thing is potted. I wonder if this is a "first use" situation like when you use a wood burning stove outside for the first time to cure the paint. Not that you should have used it outside, but that there might be some off gassing of the potting material first use. Mine is in a shipping container, so I would never notice, and as you might imagine, my controller can get pretty hot in an AZ shipping container at 60A (6500' elevation, so not like Phoenix).
The app stated 94.7 amps. Does it lie? I did not check it with m y current clamp.1640w of panel, BUT they never run at 100% efficiency.
No. The unit should put out a full 100A. The efficiency is that the PV power is more than what is getting sent to the battery. You're likely getting 94.7A because that's all the array can produce. Sun is barely two weeks from being at its most Southern position in the southern hemisphere, so you're going to be lucky to get 80% rated out of your array at high noon.
This is sounding like the situation I have with the new Victron Phoenix 3000/12 inverter humming. Tech support states I need to invest time and money ($75) into a cable and update the firmware. That "SHOULD" resolve the issue with a $1400 inverter.
There were some models and firmwares that have that issue. Once they're made and shipped, they're not getting updated until installed. If you had a pro install, they would have done it. If you're the installer, it's on you. This is true of all manufacturers on all devices with upgradable firmware/OS.
Panels are on a Rv roof. I.e. no east-ish and west-ish. How about a device operating the way it should???
It probably is. It's just stinky.
I got a reply back from tech support and he confirms high Victron controller temps. He recommends splitting it between two controllers.
Victron sech support or someone else?
Not sure about de-rating the controller. I will cognitively chew on that.
I wouldn't. I would want to keep pushing it until the stink goes away, or it fails.
I built a dump load by converting a 2.5 gallon residential water heater to 12 volt and having solar heated hot water in the camper. Probably use VSRs?
Nice!
My wife loves hot water since she is cold a lot, in particular those ice cubes she calls feet.
My wife is at the age where she is cycling between freezing or melting down covered in sweat. Enjoy the cold feet while they last.
I reduced (hobbled) the max charge current 20 percent and will find out what impact that will have on operating temp?
Again, I really wouldn't. Either you're dealing with a normal "first use" situation, or you have a defective controller. Push it... Push it real good.
Do you have a GX device? If you have a GX and an internet connection, you don't need an MK3-USB cable to upgrade the firmware. You can do so via VRM. I was shocked at how easy it was. I was very nervous when I did it, but it was painless. It does require a computer running VEConfigure3 to upload the settings.
