Victron Energy Blue Smart IP22 as RV Converter replacement?
eXodus
Hello,
I replaced my lead batteries with a 100AH LFP and now need to upgrade the converter/charger with something which speaks lithium and I don't have to watch it.
Doing some research I found the Victron Energy Blue Smart IP22 30A - which has a lot of settings and looks like it should fit in the power center. My current converter has 35A - so not that much different.
Concerns about using the IP22 as a permanent converter? It has a storage mode - in case I am plugged in for a long time.
I like User “Fully Programable” chargers;
I have zero experience with this charger, but it says “Fully Programmable” ,,, FWIW.
I figure ,,, hope ,,, any chargers buy now “Fully User Programmable” will function on future batteries of any type. Probably wishful thinking on my part.
I would want to know more about the “Fault Protection” ,,, Fuse easily & inexpensively replaceable by “the user” 🤔 ?
Hello,
I am currently testing this unit as a replacement for the OEM WFCO converter in my trailer. The adjust-ability of this unit in power user mode is impressive. It supplies the amps and corrected voltage using the smart shunt info. As for the fuse it is by the battery connection. It uses the automotive style blade fuse. At this point I would not hesitate to recommend this unit for a converter replacement.
Hello,
As a side note normally the OEM converter is a long ways away from the battery(s) In my opinion convenience and warranty concerns, 25-30 run of small gauge wire cause the typically poorly vented converter to shut down way early due to massive voltage drop. Install it near the battery. The rest of the 12 volt systems typically do not need the level of amps as the battery does.
That is actually a very good hint. True it's a long run and I think ground is going to the frame rail so even worse connections.
My battery is all the way in front - and my converter 2/3 back. And it's close to the bed, when I would mount the IP22 in the front close to the battery - it should not bother me, even if the fan would run. Best is a got a 120V outlet close to the battery.
Might just disable the converter charger in the powercenter and don't even remove it, just adding the Victron to the front just above the battery.
Thanks for the inspiration, that project just got a whole lot easier ;)
Correct
It has night mode that reduces amperage for 8 hours ( fan noise ) Best is a got a 120V outlet close to the battery. Yep
In my case I flipped the breaker off. ( Redundancy is never a bad thing )
I use the phoenix ip43 charger similar to you. I also moved the charger/power supply close to the battery and DC distribution box to reduce redundant wire runs. No fan! Mounted on a big piece of aluminum diamond plate as a heat sink,
The programming in the units is impressive. My RV charger worked well, but it was 14.6 bulk or 13.6 CV with nothing in between. So far so good, plus as was said, networking with other victron stuff
I’m looking for a “shop charger” for multiple FLA & AGM batteries. How “dialable” is the current ?
Most of the batteries I have are vehicle “starters”. Would be nice to have a 3 output unit that is individually user programmable & history data collected on all 3 charge profiles.
The 12/30 three battery version output is 10 amps on each but only one charge setting. With that said in expert mode if you know the battery specs can be set up that way. It has several settings including an adaptive mode.
It has three outputs, but if you only are using one it will put out 30 amps to a single battery. I installed one a couple months ago.
I only got a 100AH battery + the lead starter battery, so worst case it charges for 3-4h @ 30A then it should go into float / storage?
The amount of redundancy I am slowly building in this Class A RV is borderline Prepper paranoid ;)
I can charge the 12V:
- Grid (Converter)
- Generator (Onan 10A)
- Engine (140A alternator)
- 100W solar + PWM
when I add the Victron now - I am going to have 5 ways of charging the 12V - which is really only there to run lights and start the generator.
Everything else runs on 120V on my 24V big system
Ok so I am using the 15 amp version in lieu of my WFCO converter on an Epoch 460ah essentials LiFEPo until my Multiplus arrives. Did everyone just use the Li-Ion charge setting or did they do user defined settings? And if user defined, what is the best settings to go with for these batteries. Lastly should I leave this charger in place once I get the inverter/charger installed. I am doing 2 more 460ah Epochs in a 24v system with an Orion 24/12 70a converter to the single 460ah.
This was my initial version of running the Blue Smart IP22 12/30s as additional chargers to reduce the time to charge my then current 900aH 12V bank. Things to note, don't block the top of these like I did, they need room to breathe and the fan blows up through there. Don't mount them this close together.
Someone was asking about the granularity of output, I don't recall it being great, I think 15/30 amps. You can check it out in the demo library in the Victron App.
They do offer a power supply mode, which might be useful for some.
I will say they seem not to output 90A when all three are running. When on individually, 30A out of one was normal, when 3 were running, it was about 25-27A each. This was from the start, so didn't seem to be a thermal de-rating. Could have been voltage drop on the 120V side maybe?
I've since reconfigured this but didn't have an up to date photo of the Blue Smart set up.
There are quite a few threads on optimal settings for LiFePO4. I use 14.4/13.6 when I'm actively using the camper. Double those numbers for a 24 volt system.
I would use just the Multiplus for charging. If you do use the standalone charger, the Multiplus will use the incoming AC power to first satisfy the standalone charger and any leftover power will go to charge the battery.
I would not use the Orion 24/12 70amp converter to charge a LiFePO4 battery. If you're using the one I think you are, it's designed mostly for satisfying 12v loads but can be used to charge a starter battery. It doesn't have a LiFePO4 charge profile.
