Same scenario with WC 300ah, new IP22/30. 1st time charge. 18", 6 ga, ring terminals.
13.5v charge. Verified 13.5v at IP22 terminals (LiPo mode).
I confirmed via email with WC 14.6v is what they want. "We recommend 14.6v, which is better for the batteries".
I see nothing in advanced or elsewhere to change that rate.
Shot on the right is battery 1 graph complete , off Bulk. 2nd graph is battery in progress.
I know my new Progressive Dynamics RV LiPo converter puts out 14.6v
Edit: Brand new IP22 stays at 13.5v at the output terminals, regardless of Mode setting. Amps are 29+.
Example: 13.57v on "High (14.7V)"
Check the BMS in the Wattcycle to see if you have a cell or two that is coming up above 3.65 volts before the rest of the battery does. If any cell goes above 3.65 volts (approx,) the BMS will shut the charging current off for the whole battery.
Use the BMS Meta app version 1.1.5 to see the individual cell voltages.
One solar site I checked mentioned that they would return any new battery that showed a cell differential greater than 0.1 volt at full charge.
I had one battery that consistently had two cells that were always high when compared to the rest, (cell differential between highest and lowest was about 0.24 volts,) and the battery would 'trip off' at around a total of 14 volts and not allow any further charging. I had to take apart the battery and manually balance the cells. (The Wattcycle mini 100ah units are actually screwed together, and can be taken apart relatively easily. The screws are covered with plastic plugs.) After that was complete, I fully cycled the battery several times and it then would go up to 14.5 or so before the charge 'switch' on the BMS cut off the charging current.
Practically, it really didn't make much difference to how much energy was stored in that battery. (I think it took two hours at 500 ma to bring up the 'low' cells, so that works out to around 1% of total capacity regained.)
In my case, I'm running four strings in parallel made up of two 12v in series, (total of 400 ah at 24v,) so if one battery in a string 'tripped off' then the other battery in that string might not get fully charged either, since the current for that string is interrupted by the battery that was 'high.'
BTW, I balanced my cells using the resistor method. You clip in a resistor across the 'high cells,' and let it drain them off while in turn charging the whole battery at a current level matching what the resistor is drawing. My 'resistor' is a 150 watt 120v incandescent light bulb. It was pulling about 500ma across two cells, and about 350 when placed across one cell. Tungsten light bulbs work great for this kind of stuff, because the more current they draw, the hotter the filament gets which drives up the value of the 'resistance' making it somewhat self regulating. That allows you to clip it across a different number of cells without getting the current levels too far out of whack. Using a regular resistor would double the current draw going from one cell to two, and triple the current draw if you went across three cells. and you'd have to find ones large enough that could dissipate the heat generated.
BE CAREFUL messing around inside one of these batteries. If you short across a cell, things can go 'bang!' in a hurry. The BMS won't protect you from high currents if you short out individual cells or across the battery itself, and these cells can produce A LOT OF CURRENT.
