Reef Whooligan
- Mar 14, 2022
- 18
I just wanted to make sure I am using the correct settings on my Victron SmartSolar 100/50 MPPT and SmartShunt to go along with a Renogy 200AH AGM battery. I have attached pictures of both the MPPT and shunt settings and the specs of my battery are below. A couple things I'm not sure about are:
1) Is "Cycle Use" and "Absorption" the same?
2) When a range of voltages is provided is there a preference for what to use? Currently I have it set in the middle.
3) I read elsewhere on the forum that "charged voltage" on the shunt should be set .1v less than the absorption voltage of the charger, is this correct?
4) I cannot find anywhere that renogy publishes a peukert value. Victron manual says to leave it as default unless it's lithium...
5) Tail current? I don't know if that should be changed or not so it is default.
6) Battery specs have two different temperature compensation values, which one is supposed to be used for the charger?
Renogy 12V 100Ah Deep Cycle AGM Battery | |||
Operation Specifications | Mechanical Specifications | ||
Rated Capacity (77°F/25℃) | 200Ah (20 Hour Rate to 10.5V) | Dimensions | 20.6 x 9.4 x 8.8 in / 522 x 240 x 224 mm |
Rated Voltage | 12 V | Weight | 127.9 lbs / 58 kg |
Number of Cells | 6 | Terminal Bolt Size | M8 x 1.25 x 16 mm |
Reference Capacity (77°F/25℃) | C3: 152.9Ah C5: 172.3Ah C10: 190.5Ah C20: 200Ah | Normal Operating Temperature | 77°F±9°F(25°C±5°C) |
Self-discharge Rate (77°F/25℃) | 3% / month | Operating Temperature Range | Discharge: -4~140°F/ -20°C~60°C; Charge: 32°F~122°F (0°C~50°C) |
Float Charge Voltage (77°F/25℃) | 13.6V~13.8V; Temperature Compensation: -18mV/℃ | Storage Temperature Range | -4~140°F/ -20°C~60°C |
Cycle Use Voltage (77°F/25℃) | 14.4V~14.8V; Temperature Compensation: -24mV/℃ | Container Material | ABS |
Equalization Voltage (77°F/25℃) | 14.2V | Recommended Terminal Torque | 88.5~106.2 inch·lb / 10~12 N·m |
Max Discharging Current | 2000A (5 seconds) | Certification | |
Max Charging Current | 60A | MSDS | YES |
Internal Resistance | Approx. 3.5mΩ | Accessories | |
Connection Method | In Series, and In Parallel (up to 4) | M8 Bolts | *2 |
Warranty | |||
2-year material and workmanship warranty |
