I want to share my full experience with Victron MPPTs, because at this point, I feel completely let down. I’ve tested multiple units, logged data, compared against meters, even tried cooling experiments — and the results have been… disappointing.
All I knew at this point was that this is the best MPPT compared to others; looking at the real-time tracking was so satisfying. Whenever I was free, I usually kept that window open via Moto Smart Connect and streaming it to my PC via the mobile device.
After a couple of months, I bought a SmartShunt 500A, since my battery did not have a smart BMS, and I wanted to track the power discharge from the battery in and out.
After a couple of months, my dad picked up a used Rpi 3, and at this point of time, I already watched so many videos on victron, that I had plans. And this one was a surprise, so I decided to add it to the setup, I ordered the cables required to connect the units via the USB, and they both worked without any issues.
From here on, I did not need a mobile software to stream, I could just use the Victron Connect directly on PC, and see the stats. I even created the Node Red Dashboard, just for fun, not knowin, that it will be so handy in the future XD
Couple of months went on, and I noticed something off!. That one day, my batteries were full and I tried running loads, and I noticed in the MPPT window that solar power fluctuated like crazy instead of holding steady. I dug deeper, I checked my roof cam to see if anything was a cat on the solar panels or any bird movin around constantly, there was none. I checked the weather outside, and it was a pure sunny day, zero clouds floatin around.
It became obvious the MPPT was not tracking properly. Power was being wasted right at the MPPT. I made a couple of videos regarding this, and I reported this to my dealer.
Their response? “Normal behaviour.”
Detailed Report with video links: Victron SmartSolar 100 | 50
Surprise!!! The 100|15 tracked perfectly. Smooth power, proper MPPT operation. None of the “fluctuations” I was seeing with the 100|50.
So clearly it wasn’t my setup. I reported this difference to the dealer again. Completely ignored. I ended up selling the 100|50 in the second-hand market out of frustration.
Video link: Victron Smartsolar 100 | 15
And… disappointment again.
I even tried firmware updates: v1.61 v1.64 v1.68
All of them were the same, losing the MPP tracking when running under load. So it’s not firmware. It’s the hardware, or could be something else.
Detailed report with video links: Victron SmartSolar 150 | 45
It didn’t overpromise. It didn’t underdeliver. It just worked.
Meanwhile, Victron, which I paid a premium for, promised 98%+ efficiency, perfect tracking, and delivered less than a budget unit.
But after this:
I’ve put the 150|45 up for sale in the second-hand market already, and it hasn't even been a month. I can’t recommend Victron anymore. I’d rather parallel another set of 4mm² PV wires and save more power that is lost in the cables.
At this point, I’m sharing this so others don’t waste months (and a fortune) chasing performance that never comes.
The beginning — my first system
I started Solar Simple, like every beginner.- A 3kVA off-grid inverter (With Grid/Generator Bypass)
- A 60A 24V MPPT
- A 25.6V 150AH LFP Battery with 16mm2 cable and 0.5M from MPPT
- Two Bi-Facial 545Wp panels in series (42V Vmp, ~13A Imp), 35M 4mm2 PV Cables
Enter Victron SmartSolar 100|50 and SmartShunt 500A
Wanting something more reliable and efficient, I invested in a Victron SmartSolar 100|50. This was supposed to be an upgrade - better tracking, higher efficiency (~98%+ advertised), and data logging.All I knew at this point was that this is the best MPPT compared to others; looking at the real-time tracking was so satisfying. Whenever I was free, I usually kept that window open via Moto Smart Connect and streaming it to my PC via the mobile device.
Cross-check — 100|15
Not wanting to jump to conclusions, I borrowed a 100|15 from a friend with a small off-grid setup. Connected it to the same panels, same battery, same everything.Surprise!!! The 100|15 tracked perfectly. Smooth power, proper MPPT operation. None of the “fluctuations” I was seeing with the 100|50.
Second chance — 150|45
Still wanting to believe Victron could deliver, I gave them a second chance with a 150|45 (with future-proofing and expansion in mind).And… disappointment again.
- Poor MPP tracking → panel power wasted.
- ~3% sensor drift between MPPT readings and actual power going in.
- Real-world efficiency stuck at ~95%, never hitting the advertised numbers.
Real-world numbers
Just to show what I mean:- At 38V Vmp (single panel), efficiency was ~95%.
- At 1kW+ solar harvest, efficiency was still ~95%.
- Anywhere in between, efficiency was still ~95%.
- Compare that to the 100|15, which hit 98%+ even at 50W low power, or at its overheating temps of 50C, it was still converting at 97% - 98%.
The cheap MPPT story
Here’s the kicker: I also tested the first cheap MPPT (rated ~94% efficiency). And guess what? It ran like a champ. Stable tracking under any condition, always around its claimed 94%.It didn’t overpromise. It didn’t underdeliver. It just worked.
Where I stand now
I was actually planning to go all-in with Victron gear in a couple of years. The Multiplus inverter was on my roadmap. I wanted a fully Victron-based system.But after this:
- Poor MPP tracking across multiple units (100|50 and now 150|45).
- Sensor drift leading to ~95% real efficiency.
- Extra heating because of wasted energy.
- Dealer/support brushing me off for months…
My ask to the community (MPPT Experts preferred)
Has anyone else seen this behaviour of bad tracking, sensor drift, and unexplained heat in their Victron MPPTs? Or am I just the unlucky one who got multiple bad units?At this point, I’m sharing this so others don’t waste months (and a fortune) chasing performance that never comes.
