Theonlyduke
- Apr 9, 2021
- 6
Inverter/110 power question here. I just upgraded my new to me rv with 2 x lithium (old was 2 x 6v lead), 2x 300 watt solar panels to Victron 100/50 mppt, and victron multiplus 12/3000 (replacing old xantrex freedom 458 2500). Solar is working great. I connected old inverter the same way as the xantrex. Inverter works great unless I plug in to shore power. Then it trips the shore outlet breaker. If I turn to charge only it trips shore breaker after 15-20 seconds. Right now the 110 for inverter goes through a 20 amp breaker in the 110 panel, then to inverter with 2 110’s back to run outlets and microwave off inverter. I am going to re-wire the 110 panel to have auto transfer run to inverter and run the 110 panel fully from the inverter. I’m curious why it’s tripping the breaker though since it’s hooked up the same? I checked AC power in with multimeter and it’s correct. The prior installer used loose wire, 2 blue and a white for AC in so that was fun.
