AfterShock
- Apr 15, 2021
- 21
Good day gents,
First of all thank you again for helping me sorting out the type of system I needed 5 months ago. I have long waited for my RV trailer to arrive and I just got it 2 weeks ago. I started installing everything and I ran into an unforeseen issue that I am not sure how to fix. First of all, here is the cabinet (minus the batteries as it gets crowded in there with them for the purpose of the pictures)
Here are the components of my system:
2 x 200ah 12V lithium batteries installed in series (runs at about 27V)
Victron BMV smart / shunt
Lynx distributor
Multiplus 24/3000/70
MPPT 150 / 60
800W of solar panels (not currently installed but roughed in)
Orion 24/12 buck converter (deleted from the system, explanation below)
As far as I can tell, I went overkill on all the wires for a 24V system. The shore power is a 10/3 wire, then 6/3 tek wire from the inverter to the electrical panel. All other wires a 00 and 6 awg.
First of all, we had lengthy discussions 5 months ago concerning running 24V instead of 12V. The benefits were that I could double the solar array with the same MPPT, and that overall I would require smaller wiring than with 12V. the downside was the need to run a 24/12 Buck converter to feed the 12V side of my electrical panel.
Turns out, the RV that I purchased does not require a 12V battery to function, as there is a built in converter that feeds the entire 12V system when plugged into shore power. Being that as long as the inverter is on I always have 120V going to the panel, the converter is always on as well and all my 12V components work. This eliminated the need for the buck converter altogether although I did find that out too late. When I tested the entire assembly with the buck converter wired in, it instantly fried itself, I am assuming that was because of the built in converter vs the buck converter feeding the same 12V system. Thankfully, nothing else fried.
Now here is where I have some issues that I'm not certain of the source:
1. When I run the inverter but switch off the batteries, the inverter briefly goes into "low battery" alarm but then quickly goes into bulk or float mode and starts making strange sounds. The inverter is still functional at this point with the shore power
2. when I start running electrical equipment like the fridges or the fan of the AC, I can see on my Victron app that it goes up to about 750W and then cuts out and resets after about 20 seconds. Being that this inverter should run 3000W, I am a bit puzzled by the issue.
3. Shouldn't the inverter simply by-pass itself when plugged into shore power? I cannot understand why it would shut itself off considering it's not actually inverting when going from 120 to 120
4. Are there settings on the inverter that can fix this issue? I do have the dongle although I have not plugged it into my laptop yet.
P.S. As I am looking at my pictures I just realized that I am missing a ground wire between the inverter and the MPPT. However these issues occurred before the MPPT was even wired into my system yet.
Any help would be appreciated.
Lynx distributor
MPPT 150 / 60
