interestingfellow
- Aug 5, 2020
- 95
My multiplus went into low voltage disconnect at 25.8v but I have it set to 23v.
I have a Multiplust 24/300 in my camper on 560ah 2p8s eve280's
I also have a BVM712 and a RPi running Venus. The venus and VRM sees all my equipment and works as it should
I used the USBMK3 and Vconnect to make the settings changes in my Multiplus as well as genuine ve.direct cable my BVM712
Multiplust Settins
23v DC Low voltage disconnect
26.2 DC Low Voltage Restart
25v DC Low Voltage Warning
I *had* battery monitor enabled in the multiplus, but don't think I was supposed to, since I have a smart shunt and Venus
BVM712
I had low SOC alarm turned off (now set to %10 and %11 reset)
and I did have Low voltage alarm set for 24v with reset at 24.1
Why did my multiplus shut down inverting while my batter was at %15/25.8v?
And then, when I plugged it into shore power to charge, it wouldn't turn "on" inverting or charge. I waited 60 seconds and then turned it "off" at the switch on the front, and then back to invert/charge "on".Now it's operating properly.
Multiplust Settins
BVM712
