Currently in the planning stages for upgrading the cheap 1000w inverter + 2x200Ah 6v FLA house batteries in my motorhome to a Victron Multiplus 3000 (~2400w?) with LifePo.
I selected the Multiplus because of its "Power Assist" mode, allowing use of marginal shore power. Plan to use it to run AC unit (for short stints) + microwave + coffee maker when boondocking, on marginal grid or on small generator.
In any case, I'm planning to use 12v LifePo batteries (because they seem far more available than 24v ones) of some type (looking to go as cheap as possible, of course), configured in series + parallel or just parallel, depending if I go 24v or 12v for inverter. Also planning on keeping the old FLA house batteries in place since they're up in the engine compartment in space I don't need to reclaim, and connecting them + alternator to the LifePo bank via a DC to DC charger, either 12 > 24, or 12 > 12 depending on what I go with for the LifePo bank configuration, along with a switch to shut it off. The 12v FLA house battery bank would basically only power the radio when in park mode, and possibly charge the LifePo bank if the DC to DC converter is forced on when the ignition is off. I'd probably add a switch to allow the other 12v appliances to be powered off FLA or LifePo (via 24v -> 12v buck if I go with 24v for LifePo.)
So the question is, do I go with the 12v Multiplus 3000 or 24v?
The advantage of 24v seems to be lower cost on any MPPTs I would add in the future for solar, a small saving in the short chunk of wires to connect up the battery bank, and the invert may run more efficiently @ 24v (I'm having trouble fining hard data on this for the Victron.)
The main disadvantage seems to be that adding more 12v batteries in the future from different brands to the LifePo bank would be more complicated because of series configuration of 12v batteries in a 24v bank.
The advantages of 12v seems to be that I could, with careful selection, more easily expand my battery bank in the future by just adding more batteries of the same chemistry/capacity in parallel. (Is this parallel vs series mix & match a thing anyone should really worry about in the real world?) Also wouldn't need to 24v > 12v converter, though that's kinda a non-issue.
Disadvantage of 12v seems to be wiring size and potentially less efficient inverter -- and more expense on MPPTs when I finally add solar.
Anything I'm missing that might help push me one way or the other?
