mattleonard
I've had a cheap 3,000w 24v inverter with duplex plugs built-in for a portable (hand-truck style) rig. I'm upgrading to a Victron Multiplus 3000/24 - but have some questions about AC output wiring - specifically on how to keep everything compact/portable, while also minimizing voltage loss.
Given ~25a output potential - I'd love to have (2) dedicated 20a circuits (knowing that I can't pull the full 20a, nor even a full 15a on both simultaneously) with duplex outlets on each. I'd love to minimize voltage loss (I often have some 50-100' cable runs on 10/3 SOOW), so want to use at least 10/3 wire on the cart too. Here are my questions:
- Do I need to install a full breaker panel, and then also a separate 2-gang box? That's a lot of real estate on my little cart! Any more compact options, like a small 2-circuit breaker box that can have duplex outlets included?
- I've seen folks just use a power strip (with a resettable fuse built-in), cutting the plug for bare wire into the inverter. But I'm not seeing many strips that have a thicker AWG wire - most are 12 at best, usually 14. Anything at 20a? This Trip-lite seems like a possible option, but unclear what gauge wire it uses, though it does have a 20a breaker, and both 15a and 20a outlets. (I would use two of these to have 2 "circuits")
- What about wiring a L5-30 or L14-30 that could break out into Edison pigtails? Or could I go to a stand-alone power distribution box w/ the duplex? This would free up space on the cart, a locking plug would be nice, though it would be nice to have at least 1 onboard 15/20a Edison plug and not always require the separate box.
- Do I need to use GFCI's (either outlets or breakers)? This is typically used outdoors, though strongly avoiding any chance of rain.
