My camper is set up by the factory for 50 amp service. The Factory used 6/3 AWG with (about) a 12 AWG bare copper ground wire between the shore power connector and the A/C distribution panel.
I am installing a new Victron MultiPlus II 12/3000/120-50 2x120V inverter.
Question: Did I make a mistake buying the wrong A/C cable for this installation? I bought the same cable that the factory used, with that bare copper ground wire. Now, I see on the AM Solar tutorial for wiring the inverter, they used 6/4 AWG cable with an insulated 6 AWG ground.
I really don't want to have to pull out the cable I've already installed! I believe that I have successfully connected the cable on the output side, using that 12 AWG bare copper wire for the A/C ground line, in the inverter. I really don't like those push-in connectors on the new multiplus... it is hard to tell that I have successfully inserted the wires in far enough to fully engage with the connector. Might be easier with the fine strand 6AWG wires, but with the cable I bought, and that the factory used, the wire is too stiff to be easily maneuvered into the connector. The older post and ring connectors, it wouldn't be a question.
What is the difference for that ground wire on the A/C side? I will have the inverter's case grounded to the chassis with a 3 or 4 AWG cable as recommended, but that is on the DC side of things.
Thoughts anyone??
Thoughts anyone??
